Dolby Digital Receiver problem
G
gus6464
I finally got my surrounds in and I mounted them so my new 5.1 setup is ready to go but I am having some trouble with dolby digital dvds. For some reason the receiver will not output Dolby Digital 5.1 on dvds that have it. DTS works just fine as the multi-ch out light in the receiver lights up and I get a "DTS 3/2" msg on the screen. I know the receiver can do DD because I have it hooked to my Directv box and when I watch some movies on HBO I get the "Dolby Digital 3/2" message and the multi-ch out lights up. Some of the dvds I have which are DD 5.1 and do not work are Terminator 2 Extreme DVD and V for Vendetta. The dvd player is hooked up to the receiver via digital coax cable and the Directv box is hooked up via toslink.
The receiver is a pretty old Sony STR-DE675 http://esupport.sony.com/US/perl/model-home.pl?mdl=STRDE675
Seth=L
Seth=L
Does DD still work with the sat box?
Make sure your DVD player's settings are set to Bitstream and DD output is set to on.
G
gus6464
Yeah DD works perfectly on the sat box. I will check the settings on the dvd player.
Seth=L
Seth=L
Let us know on your findings. It is possible that Bitstream is set to on as well as DTS and DD could still be off. What are you using for a DVD player?
G
gus6464
Ok I changed the settings on the dvd player from PCM to Bitstream and now DD works. I didn't even know that existed, thanks Seth. It is a Toshiba upconvert dvd player with divx. Got it for like 40 bucks on sale at BB over a year ago. Now I can watch T2 5.1.
Seth=L
Seth=L
Cool, it is not a problem, it is what this forum is for.:)
