gene said:
Amps in the price range such as the Yammie are designed to give dynamic performance, NOT to deliver continuous power into a sine wave sweep with all channels driven. Imagine how large the power supply, and heat sinks would have to be. Even if you did design a linear amp to deliver say 130wpc x 7 all channels driven, it would consume over 2200 watts to achieve it. Considering that your wall outlet is limited to 120X15 = 1800 watts and the IEC mandate to limit power recepticles to under 15A for saftey, you would require 2 power cords run on two separate dedicated circuits in your home. Does this seem reasonable?
I understand, and agree with you. My point is that these tests, while being unrealistic, do show sizeable differences in similarly priced receivers. Why would one unit rate out at 32 watts, while another comes in at 87? Are we talking current limiting?
I don't own one of these lower rated receivers, and have not tried driving them to reach an audible distortion level. But if they are truely pushing less than half the rated power as some others are, I'd think distortion would rear it's ugly head quite a bit earlier than those tested with more than double the output.
I think it could play a role if you are using some extremely insensitive, low resistance speakers in a 7 channel setup. But at that point, you probalby have the cash to afford a nice multi-channel separate amp to drive them.
Purchasing receivers, or amps, is not a black and white issue. Even if all amps sounded the same, how can we rely on power specs when the manufacturers can't nail it down. Remember the MPS-1 review? They stated wattage well over what Audioholics felt should be stated.
"...maximum power ratings should be specified as unclipped (usually 0.1% THD or less) not 1% which can clearly be audible and seen on an oscilloscope as a clipped waveform" (I agree 100% - even if mfg's don't)
