I am getting 5 Behringer B2030P (
http://www.newegg.com/Product/Product.aspx?Item=N82E16836196001) bookshelf speakers. Because of a space issue I want to turn the center channel on its side. Will this effect the sound since it is not a dedicated center channel. Also, just out of curiosity, can I do this with all the speakers? I like symmetry, that's all.
Also, what would be the closest you would recommend sitting to these speakers. Do they need distance for the sound to develop? Once again, space limitations are making me consider this option. Would their horizontal orientation effect recommended sitting distance?
Thank you all for your advice.
