mitch57
My co-worker and I are having a discussion on how sound works. Neither of us is very knowledgeable when it comes to audio and video. Sorry for the long post but I don't know how else to describe the debate. This post has to do with amplification so I am putting it here.
Here's the situation. We have some PCs that have Sound Cards built into the chipset on the motherboard. The volume is so low that in order to hear anything we need to either use powered headphones or powered desktop speakers.
As a test we installed a seperate PCI sound card to see if we would see an improvement in volume without using powered headphones or speakers. We experienced a significant volume increase with the PCI sound card.
Here's where the debate comes into play.
If you put an amplifier with the same specifications between each of the sound cards and headphones/speakers will the outup volume be the same on both sound cards or will the PCI card volume be higher then the built in sound card? The amplifer used for this test is a cheap mini jack rca amplifer (radio shack) that runs off of two AA batteries and has a slider volume control.
We hooked up the amplifier to the PC with the built in sound card and the volume is definitely louder. We haven't tested it with the PCI sound card to see if it is louder then the built in sound card with all other things being equal.
In theory what should the end result be? Should both sound cards have equal output volume or will the PCI sound card be louder (assuming the radio shack amplifier is set to the same volume setting)?
