<font color='#000000'>An external amp doesn't necessarily need to "match" up with the receiver or pre/amp. There are universal connections called line-level (RCA jacks) that connect an amp to a receiver or pre/pro. Nothing about the amp can really damage or meddle with the processor attached to it. Please don't be timid about such a hookup, its not that complicated once you see it or do it for yourself. Its almost plug-n-play simple.
Damaging your speakers can be done much easier with your 2400 than an external amp...surprised? Clipping, distortion, lack of power, cats, ball ping hammers, and laser cannons are the leading culprits in the damaging of speakers. You can almost never feed a speaker TOO MUCH clean power. The drivers on the speaker(s) will simply exhibit more control, stabilitiy, better response, etc. If the amp has so much more power than is necessary, you would never crank it up so high that the extra or reserve power would damage anything, your ears would bust long before this occured.
You probably won't be implementing bi-amping (active or passive) in your setup, but you will still need strong external amplification in order to control all those passive electronics inside those studio's. Some don't realize that the passive cross over networks inside a speaker can eat up to and in excess of half the incoming juice. YIKES!!!
Once you have the line-level (RCA jacks) connections between the amp and processor (or receiver) you will simply connect the speakers to the amp via speaker cables...easy enough eh!
In order, receiver---amplifier(s)---speaker(s).
best,</font>
