Hi all,
Thanks for any help you may be able to provide!
I recently purchased an existing home that is already wired for surround sound. The living room is set up for Home Theater (which I will set up with a 5.1 speaker system). Additionally, the house has six zones (a pair of speakers in the dining room, kitchen, office, bathroom and 2 pair in the backyard). Each of the zones has a separate volume control, which I assume is also impedance matching.
I will be purchasing a multi-zone receiver, most likely the Denon 3808. My plan is to use zone 1 for the 5.1 Home Theater.
I am trying to figure out whether I can connect all six zones to an impedance-matching speaker selector and connect that to zone 2 of the receiver. Will that overwhelm/overload the receiver?
My other option would be to purchase a separate multi-channel amp, connect the six zones to that, and connect that amp to the Denon. Clearly, this is the better option, but a lot more costly. A Niles SI 1230 runs at about $800 or more. I found a company called HTD that makes a multi-channel amp called MA-1235 for $650 or so.
Which route would you choose, and which piece of equipment (amp or speaker selector) would you choose, keeping cost somewhat in check?
Thanks for your help!
