Hi there
I have some questions to ask and this might feel stupid to some. Kindly ignore my lack of knowledge.
I have the following setup at home
Dlink Lan splitter 4 ports
LG 4K tv and setup box via HDMI 1 (LAN1 connected for streaming)
Microsoft Xbox One S via HDMI 2 (LAN2 connected)
So that finished my HDMI ports of my tv
I have a custom desktop PC for gaming and music storage. LAN3 connected
I have recently got the following setup for music.
Parasound Halo Integrated Amplifier
OPPO UDP-205 4K Player
Focal Aria 906 Bookshelf pair
(Option to connect by LAN4 available but need to buy cable)
Now my questions
1) I have a DSD and FLAC collection on pc. How can I listen from desktop though the music setup.
2) I have the collection available on USB drive where should I connect and listen from (OPPO or Parasound)
3) How to get the TV sound through the bookshelf
4) How to get the xbox sound through the bookshelf
Let me know your a suggestions and as I said kindly ignore my lack of knowledge for the same.
Paul
Sent from my SM-G955F using Tapatalk
The Oppo can function as a AVR if streaming via LAN or spinning discs were the only sources. In your case, the cable set top box is a source along with the Xbox, so you need an AVR to manage that many sources.
1. Connect the PC to the 205 (via asynch USB if possible)...go to network on the 205 and it should find the PC & music files.
2. I would probably play it via the 205, but it may not matter. I'm not sure what DAC is in the Parasound, but it should be of reasonably good quality.
3. & 4...to my knowledge, you need an AVR
