Believe!
Better as in more true to the source.  It would be incorrect to state that any copy is better than any original though.  I've been playing around with it pretty actively for about 6 weeks and I think it needs to be done right to achieve ideal (and obvious) results.  If you go halfway and get copies that are no better, it's because you didn't finish the process.
I took Mark Knopfler's 2004 release "Shangri-La", which is very well recorded.  I thought "how to better this fine recording?"  The answer is simple - increased coherency.  It is present across the spectrum but most obvious in the treble.  It has never jumped out at me which cymbal was being struck while listening to my home system.  When listening to the copy, multiple cymbal strikes were immediately differentiated and I could visualize their relative sizes.  I'm not kidding or exagerating.
As to explanation, the 6moons article is very good for this.  The missing link, I think, is that there are two components to the sound that ultimately comes from your CDP.  Only one part is actually on the CD - amplitude.  This is the DATA part that causes so much confusion.  "If it isn't on the original, how is it on the copy?"
The key is that the CDP creates the other component - the timing of WHEN the data is delivered.  This is why clock upgrades are highly recommended when tweaking a CDP.  In order for the timing information to be read correctly (and sent out for amplification), perfectly square pits and lands are needed.  If they are not, a pit is read as a land.  It isn't wrong on the CD, it just isn't as clear as it could be because of the physical processes which cut the aluminum layer, creating slopes instead of squares.
This is where EAC/Plextools comes in.  These will read a sector on the CD as many times as necessary to convince itself that it knows whether that pesky slope is a pit or land.  Then it moves on.  Theoretically, you now have a perfect .WAV file on the hard drive, which is more consistent to the source than the CD was, by virtue of the many reads to achieve NOT a file with more or different information than was on the CD, but a file which is more easily interpreted correctly on playback than the CD.  This is all in the 6moons article.
This part all makes sense to me.  The burning part is more mysterious but equally important.  Mr. Koh lists a couple of ideal burners, of which I have one, but I don't know how much difference they make.  Media definitely makes a difference and there are hypotheses on that but no definitive information I'm aware of.  I imagine the burning software has an effect but I'm just using Feurio.
The part that'll be the killer for a lot of people is the PS Audio Power Plant.  When I started building the system, I got an external burner, external hard drive, and used laptop.  Dedicated system is best.  This all ran me about $300.  Thought I was done.  I e-mailed Mr. Koh and thanked him for doing all the research and writing the article.  Also told him that my power is pretty clean and wasn't planning on getting a Power Plant.
He responded that the Power Plant is a critical piece of the puzzle, as the power supplies for external CD burners are poor.  I got one on Audiogon for about $600 - double the cost of everything else combined.  I think this part is the one that will make your copies Obviously better, but it's also the part most likely to be omitted.
I've thrown a few tweaks in the system as well that I won't go into here and aren't crucial to getting things going.
As an aside, Creek has designed their new CD-50 mkII with a ROM drive instead of a conventional transport/clock.  This is said to reduce jitter tremendously.  Don't fret your expensive CDP.  A computer drive will never sound as good.
I will do some tests and submit the results here, although I don't know when.  I'm also not sure as to the value of DBT since there are entrenched camps on both sides.  A positive result would be tremendous, but I'm just not sure a null result means anything.  On the upside, this will be about the easiest blind test ever, jus' gotta switch the CD's.
