hendo
Hi Guys.
I have a BenQ PB2140 DLP projector and I have a question regarding image quality.
When running from PC 800x600 (both with std cable and 10M cable with vga booster) I get what I can only describe as (if you look close to the screen) what looks like you would see when looking at live cells under a microscope. It looks like a swarming bunch of 'cells' over the whole screen It can only be seen on light pixels/areas and can't really be seen from a distance. It may not be an issue but I can't help think it would affect the over-all quality of the image.
Using a SVHS cable from a (cheap and nasty) DVD player it does not happen - although the image quality is noticeably poorer (crap dvd player i think)
I was reading about 'Dot Crawl' but it does not seem like this given the description of Dot crawl on the web.
I do plan to buy a good quality DVD player and run via component video as the projector accepts this and I understand it is the best quality BUT I also wnat to run from PC without this annoying artifact.
Any ideas.
Thanks
Any ideas.
Thanks
