bcycle said:
1. WinISD shows a group delay over 27 ms. I know you think group delay is over hyped. 27ms seems like a lot. What can I expect from that figure. How audible is it at the lower frequencies. (no way I can hear 20hz anyway)
This is insubstantial for frequencies at subject here. Group delay is an inherant property of any filter, and it will always be a higher value for a steeper/cascaded filter. But it the values you give are insubstantial. It will have little, if any, audible effect.
But I think you need to hear [the lack of difference] for yourself under control conditions. I have prepared some samples for you to play over a high quality headphone with low bass response(if you have such avaiable). You should use an ABX comparator such as PCABX to compare the samples to each other. For example, compare a 2nd order(equals sealed) to a 4th order(equals ported) curve. Or compare the original unaltered file to either one. Get the freeware compare program here:
http://www.pcabx.com/program/index.htm
Get the files I prepared here:
http://www.linaeum.com/downloads/misc/gdelay/
The files I have provided have these properties:
drums1 = original
drums1_4 = 4th order slope at 30 Hz
Group Delay: 40Hz=17ms, 30Hz=25ms, 25Hz=29ms, 20Hz=25ms
drums1_2 = 2nd order slope at 30 Hz
Group Delay: 40Hz=13ms, 30Hz=15ms, 25Hz=17ms, 20Hz=15ms
basssynth1 = original
basssynth1_4 = 4th order slope at 30 Hz
basssynth1_2 = 2nd order slope at 30 Hz
Be sure to use the PCABX software if you want unbiased evaluation(s).
2. What do you think about the box size?
What about the size? It's up to you to choose your response characteristics so far as volume/tuning.
3. The parts that I ordered are the Dayton RSS315HF-4 12" Woofer (295-464) and their SA240 Plate Map (300-804) Do these parts look okay for this design?
Does the amp have sufficient power? Is it stabile at the impedance of the speaker you are using? If yes to both, then it's good.
4. No stuffing?? Nothing? How about bracing. Any other construction advice?
No reason to use stuffing in a vented system unless you use the subwoofer at a crossover frequency where signficant upper band energy leaks past the crossover relative to the half wavelength distance of parallel walls in the sub cabinet.
-Chris
