Denm said:
I’m trying to get the simple rundown on building my own interconnects. What is the difference between a cable for audio vs. a cable for video? Does mic cord work well? What about using RG6? How about building digital audio interconnects.
Simple answer is that the RG6 type cable will work for all those applications as it is a 75 ohm impedance cable that is used in video and digital audio but will not matter for the interconnect use. It also has low capacitance that all three applications like. Not sure about the mic cable properties.
I think you should find ready made for maybe lewss than you can make them. But, if you like to make them regardless, use the RG6 type, good all around cable
