Hi all. I have been having a problem with my Denon x3700h and I have searched around a bit but not found anything that would address the problem (or at least not that I recognized as such). There might be no fixing it, but I figured I would run it by the far-more-knowledgeable people here.
Essentially, the center channel distorts (you hear a very low volume buzz) when certain people speak at a certain frequency. I found this mostly on youtube videos, so at first I though it was just a content thing. But every once in a while it crops up in other media as well. Then I thought it was a speaker issue, because when I switch to stereo (i.e., not using the center) it goes away. But then I changed the front left speaker to center just to check, and the little buzzing was back (also used different wires, so unless two wire sets are creating identical issues, it isn't the wiring).
It is not overwhelming, and it only seems to affect a very specific frequency range, but it is definitely there. Any chance there is a fix for this sort of thing
commercial cleaning services 30a, or I am pretty much stuck with it unless I buy a new AVR?
