So I have encountered a problem in my current set-up. We recently got DirecTV and my IR repeater will not pass signals to the DirecTV receiver (H24). So here is the set-up (this worked fine when I had Dish Network and it still works for the other equipment).
In the front of the room under my screen I have an IR eye (Buffalo BEIR-350)mounted. This is wired through about 40ft of 4/22 wire to the component closet in the back of the room. The wire is connected to a the connecting block (BEIR100) which then goes out to the flashers.
Like I said the signal passes for my receiver, projector (which has a spliced flasher with 25ft of 4/22 wire in the middle), and Grafix Eye (ditto on the 4/22).
I am using a Logitech 676 remote, but the repater won't pass the origanal DirecTV remote signals either.
Now when I went through the Harmony setup and programmed the remote for the new DirecTV receiver it mentioned something about RF and had me walk through the steps to ensure the remote and receiver were set to IR. I have completed this step, but still nadda.
Any insight would be appreciated.
