Mchacona said:
I was able to get soem great info here some time ago and I'm very happy with my system and thought I'd return with a simple question. My reciever has 3 optical nad one digital coaxial connections. Is one type better/faster /cleaner or does it not make a difference. Thanks in advance and sorry for posting off topic..
Let me ask a question first... when you say digital coax.. do you mean the orange cable with the funny bulge in the middle (it's also sometime called a SP/DIF cable) ? If that is the cable you mean, you probably want to use the optical input for the CD/DVD player.
The main reason is that SP/DIF is the best way to send in your signal from an HDTV. If you either have HD or plan on getting it anytime soon, you probably want to keep that input slot open.
As Nomo suggested, you might want to run standard RCA cables into yet another input, so you can take full advantage of any "Source Direct" or "Pure Direct" 2 channel music your receiver might have. I don't know of any receivers that can use "Direct" signals using an optical input. I think it has to be an RCA input for that to work.
