Digital Coax cable for Soundblaster...
Jwheel
For the life of me, I can't seem to find a digital coax cable that will fit a SoundBlaster Live 5.1 (Model: SB0100). Anyone know where I can find a digital cable for it to connect my HTPC to my RX-V2500 reciever? This is killing me.
I'd appreciate any help.
MDS
You just need a cable with a 1/8" mini plug on one end and an RCA plug on the other. Any 75 Ohm cable will do and if you can't find one pre-made, you can likely find an RCA to mini plug adapter. Radio Shack is one place that tends to stock that kind of thing.
Here is an example of what you need: http://www.ramelectronics.net/html/RCA-mini-spdif.html
Hi Ho
Hi Ho
I use an RCA/Mini-Plug adapter and it works fine.
