Fife said:
After reading a couple articles it seems that digital coax is superior to toslink. Anybody hear differently? I question if the bend in the wire from component to component would impede the toslink signal.
Thanks
I bought a quality "glass" Toslink and am using a quality DIY Coax. If you have a player that has both, you can do what I did....
Connect one digital input into a DVD connection and the other into a CD connection.
It doesn't matter which..This way you can A/B them.
My observation is that I can't here even a tiny bit of difference. They both sound exactly the same.
There are external differences though...If your using Toslink...be very carful to not bend it too much. Especially if it's glass and not plastic.
Coax is suspectable to interference from AC cords. Make sure you route it away from them.
