did I screw up? Harmon / Kardon AVR510 purchase
dkaardal
dkaardal
I'm starting to tinker around with putting together a home theater system for myself - I bought a friends 51" Sony television (KP-51WS520) about 6 months ago and promptly stuck it in storage (long story). Now it's gracing my living room and I'm looking to add some decent sound to it.
a few days ago I won an auction on e-bay for a Harmon/Kardon AVR510 reciever, and now that I've discovered this site I'm wondering if I screwed up. The cost of the reciever was 200USD, with taxes and whatnot it'll shake out to 240.
was this a waste? My environment is a small apartment (room perhaps 12x 15), and I'm going to be picking up some speakers this week - I'd anticipated using whatever system I picked up for a few years until I bought another house. I know it's an older reciever, but I didnt figure that I needed the best and brightest for my initial foray into the HT realm.
Thoughts?
Donovan.
Rooz
$240 for a good quality reciever is no screw-up. its a good buy. amps are replaceable alot more frequently than speakers anyway. spend more time and research for your speaker choice though. imo, this is the most important thing for your set up.
dkaardal
dkaardal
well that's reassuring - thanks. :)
I've got to stop putting the cart before the horse, and now that I've found this site I'm going to do some research before buying my speakers, instead of after. Crazy, I know! :eek:
Thanks again!
Donovan
tomd51
tomd51
This receiver is definitely not a waste, you'll get very good movie soundtrack and music performance from this with a good speaker setup. As your listening area isn't too large, the 80w/channel it puts out cleanly should be plenty of power as well. The only downside to buying a receiver that's a bit long in the tooth from an age perspective is that there are newer software improvements and enhancements that you won't be able to take advantage of. Considering what you purchased, your not too far out of the water, though.
For now, this is a nice receiver to get the ball rolling and if you find out after a year or two that you'd like to upgrade, someone else likely will be willing to buy it from you that's just getting started as well.
Like you mentioned and Rooz suggested, do your research here and other online HT forums before you drop your hard earned cash. I would also suggest listening to as many speakers as possible before you buy as this area is very subjective and no one can tell you exactly your listening tastes. Other than local stores, online speaker manufacturers offer very good in home money back guarantee trials (typically 30-45 days). The only negative to this is if you're not satisified w/the speakers, you'll have to pay the return shipping which is usually $15-30 (most bookshelf sized models), but this is a small price to pay for getting exactly what you want.
If you'd like some suggestions on speakers, you may want to give us the budget your working with and if you're familiar w/any speakers and like their tonal characteristics (aka the way they sound), we can offer some suggestions... -TD
T2T
T2T
If I recall correctly, the 510 does not have Dolby PLII. This should not be an issue if you never intend to play 2-channel sources through all of your speakers. As long as it decodes DTS and DD tracks for movies and plays decent in stereo mode, you're good to go.
Enjoy your purchase! :)
Edit: I was led on by Dolby PLII and PLIIx initially, which led to even more upgrades. Now, I only love listening to music in 2 channel or 2.1 channel mode. Clearly, PLII was a bit of a gimmick for me. However, you have others who use their receivers for play back contents from their cable TV system - and prefer using PLII or PLIIx. For them, it's a great option to have. Just not my cup of tea, though.
dkaardal
dkaardal
Well, I really appreciate all the replies. I mainly intend to use the system for watching movies and listening to certain classical CD's. I don't even both getting cable, do regular television viewing isn’t a big deal for me sound wise.
The speakers that I've been leaning towards for this system are the Athena Micro 6 system. That seems to run around $750CDN at future shop, though a lad at the office here pointed out that a company called Mirage makes a set called Nanosat that can be bought at a local store here for a shade under $1000CDN.
The Athena’s seem to get good reviews on the site, though I've not seen much talk about the Nanosat system. If I lived in the states, I think it would be a no-brainer since the Athena's can be gotten for about half of the price that I can find 'em here in Toronto. If I could find a set for 400CDN, I'd just buy them on principle.
Donovan.
