Depth of Marantz SR5012
mclmk8d
I'm in the process of looking for a new media console and would like to know the depth of the Marantz SR5012 including the speaker cables attached...thanks in advance
mclmk8d
I was looking for a personal response from someone who owns an SR5012 so they can measure how deep with the cables attached, not the specs
NINaudio
NINaudio
It's going to also depend on your connectors and the wire you use. I would say to be safe, add an inch or two to account for your wire connectors and the bend of the wires.
slipperybidness
slipperybidness
For really tight spots, it is worth Right-Angle Adapters for your cabling.
Who knows what cabling you're attaching? For easier access I'd recommend something with an open back personally.
DigitalDawn
DigitalDawn
We always recommend adding 1.5 inches to the depth for wire management.
First, add a couple of inches to whatever you think you'll need. Second, don't expect an off the shelf cabinet to have exactly what you need unless it was designed/build by a company that actually understands what's needed. The one thing I have found when dealing with cabinetry is that cabinetmakers don't understand ventilation, the need for space WRT a large number of cables and the need to be able to work with the equipment when it's inside.
Not doing this to pile on, but you asked questions without specifying the connection types- if the speaker cables have banana plugs, do the wires enter from the end, or the side? If you don't intend to change the connections, I would recommend NOT using banana plugs.
Also, it's far more likely that the HDMI cables will cause more problems than the speaker wiring- HDMI plugs are a terrible design and can be very fragile, so use the most flexible cables you can find. For the short cables in the cabinet, I recommend Vanco- they're thin, very flexible and their Sure Fit series have small clips at each end that prevent slipping out of the port. If the HDMI to the TV is less than 10', you can use the same series of cable- it really makes life easier when you don't need to bend a cable that doesn't like to be bent.
