denon x3300 pre outs
bradymartin
first time im going to buy an external amp.
any recommendations for a good but not expensive 3 channel for front left right and center?
how would volume work on this type of setup? would i just turn the amp on when in use. and denon remote controls volume on 3300 and external amp?
i mainly watch movies
Hetfield
I have a 5 channel Parasound amp controlled by a Denon X3400H. Sounds awesome. I would like at Outlaw Audio and Emotiva for less expensive amps. Outlaw has a nicely priced 5 channel amp.
Sent from my Pixel using Tapatalk
WaynePflughaupt
WaynePflughaupt
Yes.
Make sure the amp has a 12v trigger input. That will it will come on when you power up the Denon.
Regards,
Wayne A. Pflughaupt
Be sure to calibrate first. My amps don't have a trigger so I use a smart power strip keyed to the avr. Three channel amps aren't all that numerous so your choices are limited. You could also use a pair of two channel amps (like maybe a pair of Crown XLS1502s) or maybe even three of the Outlaw 2200 monoblocks (and the price for three is a total of $1039).
bradymartin
looking at one of the monoliths on sale last day today.
having a problem with lip sync
optical from the denon to roku tv.
i turned lip sync on but it still off.
tried audio adjustment but cant get it right. any tips
bradymartin
You said you connected via optical, tho.
its been months since i set it up, i forgot how it works.
i use only blu -ray (for 4k player) and tv/audio (for built in roku) buttons on my remote
heres a screen shot of the inputs assign screen
and source rename. im actually not sure what i did
but when i turn tv on with tv remote, avr does turn on, but not off
so basically when i press tv/audio button on remote, the avr does say ARC. but the inputs assign screen is throwing me off. there is an optical cable to tv.
AAARRRRCCCCCCCCCCHHHHHHHH
