I have the 2200 also. It's a fine player, especially the video section, which is more or less all I use it for and some DVD-A. Audio is very respectable on the 2200, but DEFINITELY will not be as good as an outboard DAC. The 2910, IMO, is quite similar to the 2200, so I'd say a used 2900 or a 3910 would be better choice for both A/V in one unit.
A secondary recommendation would be to look into a separate, decent CD player for audio. That's what I did, and it worked great.
You say you don't watch so many movies, you might look into the Cambridge Audio 540D, which I've heard is an excellent player for redbook CDs and you will still be able to watch movies on it (though you will lose SACD capability).
ICBM will work fine for 2ch, it's just that the other 4 channels will just be sitting there, so it seems like a little overkill. In terms of what it sounds like you want to do, it's probably your best choice.
