<font color='#000000'>Hlesser;
Thanks for your great feedback.
<table border="0" align="center" width="95%" cellpadding="0" cellspacing="0"><tr><td>Quote </td></tr><tr><td id="QUOTE">A few comments:
(1) Did you compare the Coax and analog outs for sound quality on traditional CD sources? My impression, using an Rotel RSX-1055, is that the Analog outs have a much more extended and natural high end -- just the right amount of shimmer and sparkle. Was the sound different when paired with your high-priced Denon receiver? (P.S. the Rotel receiver's probably merit a review here).</td></tr></table>
I did briefly evaluate Redbook performance via the analog outs of the DVD-2900, but when compared to the AVR-5803 doing the D/A, I preferred the latter. The AVR-5803 has a superb DAC section, thus why I gave Redbook playback on the DVD-2900 a 4 3/4 rating as opposed to 5 thumbs.
(2) Could the problem you had jumping out of the menu's unexpectedly been solved by use of the Return key on the remote?</td></tr></table>
I don't know, I though I tried that. However, I will check tonight and follow-up. Thanks for the suggestion.
(3) Are there any plans afoot to solve some of the minor technical problems (e.g. power off doesn't close drawer automatically) with a firmware upgrade? </td></tr></table>
I wasn't aware of this problem. I usually never turn power off before shuting the disc tray. I will also confirm this tonight. Next time I speak with Denon, I will ask them about this.</font>
