Denon DN-508SA Professional Monitor Speaker Overview
HTKamikazee
Audioholics Sheriff
Earlier today, I did an overview on the new DN-506SA Professional monitor from Denon. As I said on that overview, Denon held a presentation on January 22, where they announced some of their new audio products for 2015. As part of their presentation, they introduced a new line consisting of 4 new monitors. One of those monitors is the new 220-watt, tri-amplified, three-way DN-508SA Monitor.
This unit was designed specifically for the support of presentation material, collaborative discussions and multimedia playback. It features a 1-inch silk dome tweeter combined with a 8-inch Kevlar woven woofer. A three-position proximity control adapts the speaker’s bass response for placement next to walls. Standard VESA mounting holes under each cabinet extend placement from tabletops and shelves to walls and ceilings. As for connections, they include balanced XLR and ¼-inch and RCA inputs to ensure simple connection to common audio sources. It comes with detachable metal grille surrounded by a liquid-smoke metallic trim. A custom waveguide ensures smooth, wide audio dispersion to the audience and, when powered on, a blue LED assists with placement orientation. Let us know what you think about this product and don't forget to share it with your friends.
Check out the following features for more details!
FEATURES:
  • Three-way, tri-amplified reference monitor.
  • Frequency Response: 38Hz – 22kHz.
  • Wide dispersion for use in meeting rooms, classrooms, and pro-audio applications.
  • 8-inch Kevlar reinforced low-frequency driver.
  • Dedicated 5-inch Kevlar reinforced mid-range driver.
  • 1-inch silk dome tweeter with custom waveguide for non-fatiguing treble.
  • Coaxial mid+high drivers save space while preserving time and phase cohesion.
  • Kevlar woven woofer provides tight, accurate bass response.
  • Ported, acoustically inert coated MDF enclosure.
  • 150W LF amplifier; 35W MF amp; 35W HF amp.
  • Built-in 3-position proximity switch control adapts bass frequency response when mounted close to a wall.
  • Adjustable low, mid, and high frequency response curves with custom crossover.
  • +/- 6dB variable boost/cut at 100 Hz, 1 kHz, 10 kHz (with bypass switch).
  • Balanced XLR and ¼-inch (6.3mm) and RCA input.
  • Shelf, desktop or wall (VESA) mountable.
  • Convenient LED light guide assists in placement.
  • Detachable metal grille with elegant trim accents.
  • Sold in single units.
Price: $399.00/each.
Georgel
Georgel
Interesting,looks like an M-Audio M3-8 Studio Monitor with a face lift,they both have the same exact specifications.I`m curious if they made any improvements to the electronics,or if they have exactly the same parts.
Specifications
  • Frequency response: 38 Hz – 22 kHz
  • Crossover frequency:
    • Low-Mid: 450 Hz
    • Mid-High: 3.9 kHz
  • Amplifier Power:
    • Low-frequency amplifier power: 150 W
    • Mid-frequency amplifier power: 35 W
    • High-frequency amplifier power: 35 W
  • LF cutoff switch: flat, 60 Hz, 80 Hz
  • Equalizer Controls:
    • LF: ± 6 dB boost/cut at 100 Hz
    • MF: ± 6 dB boost/cut at 1 kHz
    • HF: ± 6 dB boost/cut at 10 kHz
    • Bypass switch
  • Polarity: Positive signal at + input produces outward LF cone displacement
  • Input impedance: 20 k Ω balanced, 10 k Ω unbalanced
  • Input sensitivity: 85 mV pink noise input produces 90 dBA output SPL at 1 meter with volume control at maximum
  • Protection: Output current limiting; over-temperature; transient on/off protection to prevent speaker "pops"; subsonic filter; external mains fuse
  • Cabinet: Wood veneer front baffle with vinyl-laminated cabinet
  • Size (W x H x D): 10.6" x 17.1" x 11.2"; 268 mm x 434 mm x 285 mm
  • Weight: 28.2 lbs.; 12.8 kg
