On January 22, Denon made an announcement that involved the addition of several new audio products to their already large catalog. As part of their announcement, they mentioned the addition of 4 new monitors specifically designed for professional applications. One of those monitors is the new bi-amplified, two-way DN-306SA Professional Monitor.
Designed for the support of presentation material, collaborative discussions and critical multimedia playback, the 100-Watt DN-306SA combines a 1.25-inch silk dome tweeter with a 6-inch Kevlar woven woofer. Denon included a three-position proximity control which adapts the speaker’s bass response for placement next to walls and standard VESA mounting holes under each cabinet to extend placement versatility. Balanced XLR and ¼-inch (6.3mm) inputs were also included to ensure simple connection to common audio sources. You will also find a detachable metal grille surrounded by a liquid-smoke metallic trim. For better convenience, a powered blue LED has been added to assist with placement orientation.
Take a look at the following features and specifications and don't forget to share your impressions with us!
FEATURES AND SPECIFICATIONS:
- Frequency Response: 45 Hz – 22 kHz.
- 60W LF amplifier and 40W HF amp.
- Two-way, bi-amplified reference monitor.
- 6-inch Kevlar reinforced woven low frequency driver.
- 1.25-inch silk dome tweeter with custom waveguide for non-fatiguing treble.
- Ported, acoustically inert coated MDF enclosure.
- Built-in 3-position proximity control adapts frequency response when mounted close to a wall.
- Balanced XLR and ¼-inch (6.3mm) input.
- Shelf, desktop or wall (VESA) mountable.
- Convenient LED light guide assists in placement.
- Detachable metal grille with elegant trim accents.
- Sold in single units.
Price: $249.00/each.
