Frankly speaking...
I have little expertise for designing loudspeakers but have done various acoustic evaluation projects with Dr.Toole & Dr.Olive, and have noted certain key discussion design points. 1 point they have always stressed was that the loudspeaker design including cabinet, grille, baffle board and electrical driver/x-over should be as neutral as possible so that the room and its surrounding furnishings have minimal bearing on its acoustic performance. Basically they wanted the loudspeaker to sound the same regardless of the room.
Another loudspeaker acoustic point I learned from Ed May(30 years with JBL & Marantz) he wanted the loudspeaker's frequency response to be
Flat on Power basis... Basically the x-over frequency points should be below that respective driver's max frequency, as a drivers starts to beam when maxed out and then having its output dispersion pattern starts to collapse.. Also he would use conjugate circuits within the x-over as to maintain a constant impedance load to each driver.
Just my $0.02...
