DENON AVR-X6700H Music vs Home theater
matts13
Hi everyone, Is there a way to have a "pre-set" (pre-set 1 and pre-set 2) 1 being when I just want to listen to music I select "1" and it will set my mains and subs on only? and when I want to go back to watching movies select pre-set 2 and it sets everything back to surround sound? is something like this doable?
Thanks
William Lemmerhirt
William Lemmerhirt
Normally if you select “stereo”, it will do that. Then just select a sound mode you like for surround. Depending on the AVR, it might default to stereo when it detects a 2ch signal.
Trebdp83
While new receivers will remember the last sound mode used for a particular device and signal, they will default to a particular sound mode for output of a particular signal.
As often as I switched sound modes in the middle of playback with my Denon receivers, I never once used the Quick Select feature. It stores settings for a quick recall of them for a given input source.
The X6700H features Quick Select as well as separate 2CH Playback settings for playback of two channel signals in Direct or Stereo mode.
So, for a disc player playing multichannel movie tracks, one can store their selected Source, Sound mode, Audyssey and Speaker settings with a long hold of the Quick Select 1 button. Selecting the “Auto” Sound Mode here for recall with Quick Select will result in a Straight decode of various Dolby and DTS signals.
If one also likes their Front speakers played at Full Band with bass complimented by the subwoofer using the LFE+Main setting when selecting Direct or Stereo mode with two channel music signals, the settings can be stored in Quick Select 2, 3 or 4 as well.
The 2CH Playback Speaker and Subwoofer settings must be made manually or will copy the Main Speaker and Subwoofer settings by default. The manual settings will apply to all devices outputting two channel analog or digital signals.
HEOS has a couple of preset options of its own as well when using it for music playback.
