Hi - Just purchased a Denon AVR-4310CI yesterday. I wanted the new BluRay codecs that my current AVR-5803 didn't have.
But I have 2 show-stoppers that have me thinking of returning it tomorrow.
For the life of me, I can't get any audio to come out of the 4310 from my Sony BDP-CX960 BD DVD player. I get great video, but zero audio thru HDMI.
I verified the HDMI cable is good - I hooked it up directly to my TV and I get everything.
I also have a DirecTV HR20-700 hooked up with HDMI, and this is working perfectly. I swapped the HR20 to the DVD input, and it worked fine.
Seems like a handshake issue, no?
Second issue - My ethernet port seems frozen. I can't get anything to connect. I'm using a Cat-6 cable wired directly to my router. When I go into my router's status page, the port shows "cable disconnected".
For the heck of it, I tried an old trick of hooking up the 4310's ethernet port to my laptop, and I couldn't see it there either. Used a different cable too.
Do you think I have a lemon, or do you have any ideas I could use? I really like the sound out of this unit - Audessy did a much better job than I did with my RS sound meter, and I don't want to have to re-install my AVR-5803 if I don't have to....
Thanks in advance for any help you can lend!
