My 3805 has a bit of trouble pushing my Polk RTi10 towers at higher volumes, and they're an 8 ohm nominal 89dB speaker. I think yours are 4 ohm, so I would think you may want to add a separate power amp if you plan on driving more than two speakers. I've called Denon and asked if they could recommend running the 3805 with 4 ohm speakers, and they've told me no, but nowhere does it say on their site not to run 4 ohm speakers. I think there is a precautionary statement in the manual about running 4 ohm speakers with the 3805.
Any solid Adcom, Bryston, etc... amp at ebay (slightly used) should do fine. I don't know if I'm sold yet on the pro Behringer A500 (the $179 amp that's been pushed so much). It's said to put out 160 watts into 8 ohms, but at 18lbs., I'd have to test it out first to recommend it.
Are you running more than two speakers, or is that it? How large is your room? How loud do you listen to music/movies?
