Denon AV receiver only has 1/2 above for vent....crap
jsm1847
So I got my first receiver in my life a Denon S530BT from recommendations here on Audioholics. I squeezed it in my shorty entertainment center and realized this thing might need to breathe. Sides and rear are completely open, but I'm thinking 1/2 above might not be enough. It's not gonna work is it.....? I might just have to build shelves in my media room. I know manufacturers recommend at least 4 inches above.
Thoughts?
Hetfield
Thoughts?
Yeah I would be nervous with that little room. My processor and amp are out in the open air.
Sent from my Pixel using Tapatalk
1/2" I think would encourage too much heat build up and too narrow for a fan to fit on top....change places with the processor?
ellisr63
ellisr63
Bryce_H
Bryce_H
I used to have a closed AV cabinet with my AVR in it. I rewired several computer fans to draw the hot air out and it worked like a charm. I drilled 120mm holes in the cabinet with a hole saw and then mounted the fans. However, I couldn't leave the cabinet closed with the PS3 running
Bucknekked
Bucknekked
Thoughts?
As others have already posted, leaving your AVR with no breathing room is a situation to be avoided.
You are also correct in that the manufacturers want 4 to 6 inches. They aren't kidding, the thing needs to breathe.
The AC Infinity fans or fan units are a great solution, but, you still have to have more than 1/2 inch.
In the short term, it probably won't hurt you, but in my life, short term turns to long term in a heartbeat.
I'd solve the issue so I could forget about it.
I put mine out where it can breath AND put in a nice AC Infinity fan control unit with fans. Works like a charm. Set it and forget it. Then you can you what you set out to do : enjoy the music !
Bucknekked
Bucknekked
regarding the PS3: man do those run hot or what? I couldn't leave any cabinet closed while the PS3 was on. If your microwave oven ever goes out, just throw whatever you need to cook on top of the PS3.
Curious which model of PS3 you guys had? I have the later slim version and while it runs a bit warm, nothing unusual or like some avrs I've used....
M Code
M Code
Note that just a 10% increase in a unit's average temperature can reduce its reliability by up to 50%...
Just my $0.02... ;)
Bucknekked
Bucknekked
Just my $0.02... ;)
"75% of quotes on the internet are made up".................Abraham Lincoln
or my favorite
"60% of the time, it works every time"...........From Ron Burgundy
:):D:)
M Code
M Code
or my favorite
:):D:)
Hmmm..
Key words are up to 50%.... :confused:
Just my $0.02... ;)
jsm1847
Ok, so here is my fix....hahaha
I decided to make a built in wall shelf, then decided id like it as a secret door. This turned out pretty good. Thanks for all your help!!!!
Bryce_H
Bryce_H
1st Gen PS3...it was the best bluray player for several years :eek:
