Speaker impedence
It will also make a difference if all of the speakers are 4 ohms, or just the fronts. The efficiency of the speakers, size of your room, distance from the speakers and listening preferences also factor into the equation.
For example, if all speaker are 4 ohms, your room is over 3000 ft^3, and you like to listen at "reference" levels for hours at a time, then it might be a bad combination for any receiver.
