hi,
Looking for a new AVR, denon 2805 or 3805. Just to ask something about the power :
i understand that, "standard" power for avr should be something like : 100W all channel driven, 8Ohm, 20Hz - 20KHz, with 0.08%THD. ok..what is the denon 2805 equal power mean : Fully Discrete, Equal Power Seven Amplifier Channels, 100 Watts Each (2805), 120W (3805)? is this Equal power = all channel driven at the same time? or just quoted for 2 channel?
Power Amplifier Specification for 3805 :
Front ............................................... 120 W + 120 W (8 ohms, 20Hz - 20kHz, 0.05 % THD), 160 W + 160 W (6 ohms, 1 kHz, 0.7 % THD)
Center............................................. 120 W (8 ohms, 20Hz - 20kHz, 0.05 % THD), 160 W (6 ohms, 1 kHz, 0.7 % THD)
Surround......................................... 120 W + 120 W (8 ohms, 20Hz - 20kHz, 0.05 % THD), 160 W + 160 W (6 ohms, 1 kHz, 0.7 % THD)
Surround back ................................ 120 W + 120 W (8 ohms, 20Hz - 20kHz, 0.05 % THD), 160 W + 160 W (6 ohms, 1 kHz, 0.7 % THD)
and the denon actual power for ALL channel driven is actually less than 120W?? or there is no such ALL channel driven at the same time? we don need ALL channel driven at the same time just becoz not all channel produce the same sound level? front always > rear?
some Pionner quote their power with 1KHz, and heard the different is about 20% compare to full bandwidth 20Hz- 2KHz, true?
thanks
