Denon 3300 sound problem
PottyTrained
My receiver's audio dropped off about 40% and I can't figure out why. My TV's audio is fine, I don't think the settings have changed but I did push some buttons on the front of the receiver instead of the remote. It seems the surround system is muted, I have not tried a usb stick with music yet, but I will when the wife leaves for church..lol
I have a feeling It has something to do with the Zone buttons. But not sure.
PottyTrained
I just tried the receiver and It seems just fine, so I guess It's the TV to Surround that is the problem. Can a Optic cable go bad? or is it something else?
William Lemmerhirt
William Lemmerhirt
WhT button do think you pushed? There is a surround parameter button on the right side. Try scrolling through those maybe? Maybe you engaged direct mode or something else? Find whatever button you pushed as that’s certain to be the problem.
If the optical link is kinked, bent or coiled too tightly, the sound may become intermittent, but that's about the only problem I have found with these, other than what happens when the plug comes out.
Verdinut
Verdinut
On your remote, you might have inadvertently depressed one Quick Select button. This happens to me sometimes. By using the Sound Modes buttons, you should be able to get your full volume back.
William Lemmerhirt
William Lemmerhirt
That’s kinda what I was thinking. But he said he pushed one on the front of the AVR. Same difference, but I agree the likely suspect.
