Denon 2805 and loud humming sound with sub? Help!!!
N
newaudiophile
I have hooked up my Denon 2805 to my subwoofer, and when i do that i get a loud nasty humming sound...why is that? i hooked up a RCA cable from the Denon (the red one) to the Sub (line in). This sound only happens when i hook up the sub....no problems with the fronts/rears/center....
Please help!
MacManNM
MacManNM
Please help!
Either a bad cable or bad ground in the sub amp.
N
newaudiophile
thanks....
any chance it could be the receiver?
if it is the cable....i just used a regular RCA cable, is there a better one to use?
MacManNM
MacManNM
newaudiophile said:
thanks....
Yes and No.
The receiver's RCA connector could have a bad ground.
IMO a cable is a cable as long as the connectors are clean and it is sound. Try a different cable, also try hooking the cable up to another output on the receiver, but dont play anything through it. Just see if the hum goes away.
Buckeyefan 1
Buckeyefan 1
Does your sub have a three prong plug? If it does, it's most likely sharing the same ground as the receiver and creating a 60Hz hum. Try a three prong to two prong adaptor and "float" the subwoofer plug's ground to the wall socket. See if that helps.
N
Nick250
That's what fixed the hum on my Hsu VTF 2.
N
newaudiophile
I checked the back of my sub.....
i have the following:
Line out (white and red) and Line In (white and red) - RCA cable fits in this
Hi level In and Hi level Out - speaker wire
I am not sure if a 3 to 2 prong would fit in this, would it?
Spiffyfast
Spiffyfast
The 3 or 2 prong is the power cord on your subwoofer, not the inputs or outputs.
shokhead
shokhead
Yes,it will fix it.
