definitive bp10's help
peetoad
I need help choosing the best reciever/amp for the definitive bp10 tower and superfield 15 sub. I would like to use these in my HT set up. The bp10's are supposed to be compatable at 4 to 8 ohms. I certainly don't want to blowup either the amp or speakers so I need some advice?? I will be using only 2 or 3 video sources and would like to stick with RGB and digital. I am limited to about 1000 for an amp/reciever... suggestions? I am really new at this and will need help setting it up as well.
thanks in advance...
phil in vegas
:confused:
Pyrrho
Pyrrho
Now, with your speakers, it would be good to know what the impedance really is, as saying "compatible with 4 and 8 ohms" doesn't really tell us, though it is suggestive that it is really lower than 8 ohms. I read in a review that they are 6 ohms and a sensitivity specification of 89 dB. That would not be too difficult of a load, but if you play your system at deafening levels, you would want to get the most powerful receiver you can (just remember, though, it takes a doubling of power to add a mere 3 dB of SPL, so a small difference in power output is not likely to be noticed). Reading a bit further in the review, though, I see they have a minimum impedance of 3.5 ohms at 200 Hz. That is not good for most receivers these days, and you might want to get something that puts out a lot of power into 4 ohms.
Given that, you might be best off getting something like the Pioneer VSX-1015TX which retails for only $499, and can be had for less. It should be fine if you don't listen too loud, and depending on your other needs. At its price point, I don't know of anything better, or even very close, to its performance. You can read about it at:
http://www.pioneerelectronics.com/pna/product/detail/0,,2076_4153_209686388_tab=B,00.html?compName=PNA_ProductDetailComponent
(If you want to download the owner's manual and read it, you will need to register, but it is free.)
I am suggesting this receiver for a couple of reasons; first, it is great for the money, and second, it leaves you with enough money to buy a separate power amplifier for the front speakers if needed, which will take some strain off of the receiver.
peetoad
What testing eq do I need to find the impedence
Is there some testing eq I can buy to determine the exact impedence of the bp10's, and the sub? Also doesn't the min-max impedence mean the speakers will operate on any in within that range? I do realize that the lower the impedence the greater the power needed to drive them. One of the reviews I read indicated they could be driven at only 30 watts per channel... but that would surely blow a reciever if cranked even minimally!!
I have only been looking at receivers with a minimum of 100 watts per channel and some that are higher than that.
The definitive superfield sub has both high level and low level inputs and outputs for both right and left channels (high level are banana type connectors and low level are standard rca type connectors??).
I am a little confused about whether I can drive the right and left channel (on a HT system) through the sub and the rears and center directly off the reciever. Is this possible?
I really appreciate any and all advice on this issue. I would really like to keep these speakers and use them in my HT set up if possible!
thanks
phil
