Def Tech Speaker Combo Decision...
K
kuko92
Hello. I am having a bit of a dilemna...some people tell me I need a bigger center channel...some people say buy 5 satellites...I don't know what to believe anymore...I would think your center should be a little bigger so it can reproduce dialogue and vocals which movies and music highly demand but I'm not sure anymore...anyone have advice? Basically it's between purchasing 5 DefTech 800's...or 4 DefTech 800's and a DefTech 1000 Center...please help me out! Also if anyone has any info on the Aperion 4B's please tell me I was considering those as well. Thanks in advance!
njedpx3
njedpx3
Tough Decision - Toss-UP 1000 center is perfect match for 800s
I would off-hand have said get 5 alike, but in this case I checked the specs of the Pro1000 and it is a perfect match for the 800s (see specs below).
In your case the 1000 center might add a little more and since you mentioned movies ( center primarily provides dialog) I would go for the 800s and a 1000 center. Sounds like a very sweet system.
specs:
ProCenter 1000 :Specifications
Dimensions | Metric :14-3/4" W x 5" D x 5" H | 37.5 x 12.7 x 12.7 cm
Driver Complement :One 1" pure aluminum dome tweeter; Two 4-1/2" BDSS upper bass/midrange drivers; Two 4-1/2" pressure coupled bass radiatorsFrequency Response :47 Hz – 30 kHz
Impedance :Compatible with 8 Ohms outputs
Sensitivity :90 dB
Recommended Associated Amplifier Power :10 – 200 watts
A/V Receiver Crossover Setting :80 Hz
Inputs :One pair of 5 way binding posts
Available Finishes :Gloss Black; Gloss White
Accessories :Leveler Foot; Two ¼ 20 insert cover plugs
Mounting Options :On Shelf with included leveling foot; Equipped with two ¼ 20 sized threads to accommodate on wall mounting with two ProMount 80 (available separately)
Packaging :One to a carton
Weight | Metric :6 lbs | 2.7 kg
Warranty :5 Years
ProMonitor 800 :Specifications
Dimensions | Metric :4-3/4" W x 5" D x 8-3/8" H | 12.1 x 12.7 x 23.8 cm
Driver Complement :One 1" pure aluminum dome tweeter; One 4-1/2" BDSS bass/midrange drivers; One 4-1/2" pressure coupled bass radiator
Frequency Response :57 Hz – 30 kHz
Sensitivity :89 dB
Recommended Associated Amplifier Power :10 – 150 watts
A/V Receiver Crossover Setting :100 Hz
Included Accessories :Tripod Base; Two ¼ 20 insert cover plugs
Mounting Options :Vertically: On Shelf with included tripod base; Equipped with rear ¼ 20 sized thread to accommodate on wall/on ceiling mounting with aftermarket mount(available separately); Equipped with bottom ¼ 20 sized thread to accommodate ProStand 600/800 stand mounting (ProStand 600/800 available separately); Equipped with keyhole mounting slot for flush mounting
Weight | Metric :4 lbs | 1.8 kg
Warranty :5 Years
Enjoy ;)
The Forest Man
GlocksRock
GlocksRock
Go with the better center, since more than half of what you hear when watching tv/movies comes from the center channel, you don't want to skimp there. For music it won't make a difference since you won't be using the center anyway. Plus def tech's are voice matched so you won't hear a difference in timbre anyway.
db682
I have that exact setup. 1000 - center, 4 - 800's surrounds, and the supercube 2 for sub. All powered by a Yamaha reciever. Now I'm debating on jumping on the DefTech outdoor speakers that nobody knows anyhting about.
