Def Tech Reference In-Walls
F
flyfish23
Does anyone have any experience with the top of the line In-Walls from Def TEch?
Also, does anyone feel that dual Def Tech in wall subs are good enough for a HT set up?
rolyasm
I have heard the in-ceiling,but not the in-walls. The ceiling speakers were nice, but not great. If you are not set on DT, I have auditioned a set of Energy RC in-walls, and they were amazing. Also, the Atlantic Technology in-walls were super also. Good luck.
Roly
F
flyfish23
Thanks, i agree with the in-cieling but i heard the reference in walls are awsome.
AVRat
AVRat
Unfortunately, I have not heard the new reference in-walls, but they would be one of my first choices for a little higher budget in-wall system. Are you going with a 5/7.# system? Do you prefer mono- or bi/di-pole surrounds?
Depending on the size of your room (H x L x W), a dual sub setup may be sufficient. Chet @ Def Tech should be a better source, send them an email.
F
flyfish23
I think I am going with a 7.1 but my question is should I use direct radiators of bi-pols for the sides and surrounds?
AVRat
AVRat
Generally, multi-poles are used for the side-surrounds while either could be used for the rears. Room layout and preference is the determining factor though.
jca93
I have UIW-94 front L/C/R and UIW-83 surround and rear speakers. I'm far from an expert, but I think they sound pretty damned good. I also have a pretty good 12" sub to bring out the bass, but I think the speakers are pretty good by themselves.
jason a.
Pioneer elite vsx-74
panasonic dvd s-77
panasonic dmr eh-85 dvd/hdd recorder
carver tfm 25 amp
sony cdp-305 cd changer
Def tech UIW-94 fronts and UIW-84 surrounds/rears
velodyne dd-12 subwoofer
onyko tape deck
sony vhs
