Thanks for the reply AVRat. Have you compaired the 2500 & the 2002? When I started the thread I sent a copy of it to Chet @ Def. Tech. Here is his comment:
Given a choice, I'd recommend going with option #1. You'll hear a greater improvement in the sound of your home theater system by using a better center speaker (and lesser surrounds) than using a lesser center speaker and better surrounds. (The center speaker plays 60% - 65% of all the sounds recorded on most movies. Having a better center speaker really makes a difference.)
If the 2500 is that much better than the 2002 then I can justify spending the extra cash. If you have compaired them let me know what you thought.
Thanks
