I picked up a Harmon Kardon receiver (AVR 510) from ebay today, and when I plugged everything in... nothing happened.
When I plug in all the speakers (brand new Athena Micra 6 system), all I get is very faint sound - and that's when the volume is at the absolute max.
I tried resetting the unit, no help
tried unplugging the digital coax and using just left and right RCA - nothing.
I unplugged all the speakers, then plugged the left and right channels in. No luck
I switched from the cable that I bought (generic 16 gauge stranded with banana plugs that I put on) to the crappy cables that came with the Athena speakers - still only the faintest sound when I crank the volume to max.
I am getting something from the subwoofer - again, when the volume is max.
Is the receiver dead? It didn’t come with a remote, so I can't go into the setup menu - but I should be able to at least HEAR something through the speakers, no? I had intended to order a remote from Harmon Kardon... but if this unit is dead, then I'll just take it back to the seller and go and buy a brand new one.
help?
dak.
