Unregistered said:
Comparisons of sampling frequency and bit depth are valid because higher sampling frequency and greater bit depth result in more accurately representing the original analog waveform. Bit rate comparisons on the other hand are meaningless. One may prefer DTS 96/24 over 44.1/16 CDs but the difference will be because of higher sampling frequency, bit depth, and multiple channels - NOT because of bit rate.
True, that the higher sample rate will result in a more accurate representation of a waveform,
IF the waveform contains frequencies higher then the CD format. Then their is the standing question of what benefit a higher sampling rate provides in terms of audibility. No one has demonstrated a need for greater bandwidth for audible reasons in a valid test. I like to reflect on the moment, and observe the massive percetual research projects that were produced to determine the specs for CD. Then look at the ZERO
valid projects with positive results done in perceptual research to demonstrate audible benefit of higher resolution. Hmmmmmmmmmmmmmmmmmmm. Come to think of it again, perhaps Sony knows it would be redundant to perform once again, tests that have already shown the maximum detectable high frequency spectra of humans. But, it's fun to see the gimick literature like on their site showing a square wave looking more 'square' with the SACD bandwidth compared to RBCD. Leave it to the imagination to correlate(improperly) with audibility.
Good marketing trick! Hey, mtrycrafts, didn't you have a link of a 'fixed' Sony produced SACD vs. CD test where they were caught cheating? MOre interesting food for thought.
-Chris
