Dayton Sub-120 setup
iTarik
iTarik
Does anyone know how to setup the Dayton Sub-120? Crossover frequency settings,volume control,phase switch ...
iTarik
iTarik
I am not sure I understand. :confused:
I already have the sub. I just wanted the settings setup.
jar
I have same sub, I'm having trouble with set up. Do I need a y cable to into back of sub for the input red and white?
iTarik
iTarik
I am not using the Y cable even though I have it. I am using a sub cable from my receiver pre-out to low input L (the white one)
jar
I went to one our audio places and asked about it and they said I needed the y cable adpt this is the only way I could get it to work, I tryed everything switching the line to the red etc I hooked up the cable then had to put sub plus on in order to work, it wouldnt work in just sub on. Anyway I'm pleased to say it shakes the floor. I called the place where I got the sub and they said I shouldnt of had to put in both input jacks should of worked on one line. He then said my cable was bad, which I dont agree because I'm still using the cable just with a short y cable adpt. Not unless one of the ends was bad.Anyway working now thank god I really didnt want to send it back since I'm from Canada. Thanks for your help:)
