The Dayton Audio SUB-1200 12" 120 Watt Powered Subwoofer Giveaway is Here! To show some love to our loyal Audioholics readers, we’re partnering with Parts Express to give away one of their
Dayton Audio SUB-1200 12" 120 Watt Powered Subwoofers.
The Dayton Audio SUB-1200 12" powered subwoofer system is capable of delivering realistic, room-shaking home theater bass effects—even in larger rooms.
For more information about this subwoofer, please take a look here:
To enter the Giveaway, simply:
- Register to receive the Audioholics and Parts Express email newsletters.
- Respond using that same address if you are contacted as the winner.
PLEASE NOTE: By registering for the contest, you are agreeing to receive both the Audioholics and Parts Express email newsletters.
PRIZE DESCRIPTION
Features:
1. Line Level Inputs
The line level inputs are used to connect pre-put or preamplifier outputs directly to the subwoofer amplifier's internal crossover. These inputs are summed to mono. This is the preferred way to connect the subwoofer amplifier. If you have a mono line level signal from a "Pro-Logic" or "Dolby Digital" receiver use the right "red" input. Note: If a LFE mono output is connected, set the crossover point to maximum.
2. High Level Inputs
If preamplifier outputs are not available, use the high-level (speaker) inputs. The speaker level inputs can be connected directly to the amplifier by inserting the speaker wire.
3. High Level Outputs
There are also high level outputs which can be used to connect to main speakers or to another powered subwoofer with high level inputs. Note: High level outputs are paralleled to the high level inputs with no high pass filter.
4. Crossover Frequency Control
Continuously variable from 40 Hz at 12 dB/octave. Set the frequency control to where the audio does not sound "muddy", normally between 60-80 Hz. Note: If a LFE mono output is connected set the crossover point to maximum.
5. Gain Control
Adjusts the output level of the subwoofer. Set the level to where the bass frequencies blend with the other speakers. Note: Most people have a tendency to set the level too high, which makes the audio sound "boomy".
6. Phase Switch
Selectable between 0° and 180°. This assists subwoofer placement. The correct position will be the one that provides the most apparent bass output.
7. Power Switch (Auto On/Off)
When the power is in the auto position, the amplifier will automatically turn on when a signal is present. Note: In auto/off mode, the power on LED is always on (red), even when amp is in rest mode (off). The power LED will turn green when the unit is activated.
PRIZE: One Parts Express Dayton Audio SUB-1200 12" 120 Watt Powered Subwoofer.
(Retail value: $229.99)
IMPORTANT NOTE: Prize to be sent between April to May 2018.
RULES: To enter, simply provide email address and follow confirmation to sign up for the Audioholics and Parts Express newsletters. One new subscriber who joins between 3/1/18 to 3/31/18 will be chosen at random as the system winner.* But don’t wait, the entry period ends March 31,
2018 at 11:59 PM EST!
*Winner must be U.S. or Canadian resident, 18 years old or older with valid email address.
REMEMBER YOU'VE GOT TO BE IN IT TO WIN IT!
Contest ends 3/31/18 at 11:59 PM EST
