Dayton 18" HO Ported Build Thread
bassbear
well, not sure when and what really happened - looks like Rob Harrison used new driver parameters and shared with us nice documentation in this thread:
I'm even more confused because one of my local stores (europe) still uses old parameters:
while the other european stores, us partsexpress and manufacturer have already new in place:
I assume last link should be the best source of truth :) correct?
Well they sure mucked that driver up. They have made it more of a pro driver, with increased sensitivity. It also moved more to a sealed design. You can only get an F3 below 30 with an extended bass alignment. By the look of the FR they have also cheapened the motor system.
That is a real pity.
The enclosure volume has not changed that much, but the porting is a little different.
The data on the Dayton site and Parts Express agree.
I have attached a pdf using the updated specs.
Unfortunately that driver will have lower SQ than the former one.
bassbear
Thanks a lot for quick remodeling. If the driver is not that nice now is it still worth using or is there any other driver i can buy instead in similar budget? (no need to be 18" if have better parameters for BR)
My room: 50 m^2 attay
There probably is a better solution. What are your specs, size, cost, bass extension and power handling? I am a little busy at the moment, so it could be a while before I get to it.
bassbear
No rush :) i don't have pressure to biuld it imidiatelly.
Will it be still based on that driver or should i create new thread to not make offtop here?
Would like to build sub which will help my kef q950 + q650 in music and HT in ~ 50m² attic.
Expected low bass / box size > 200l + is ok . Driver should be available in EU. Budget about $600 - please note that this driver cost over $600 in EU.
Inicially I had plan to use T.AMP 1050 MK-X in bridged mode but I have noticed recently that it can't go to 4 ohms in bridge mode so need to stay on 2x520W@4Ohm (lowest possible impedance accepted). Not sure if it can go with that big speaker. Possibly i will have to buy amplifier as well or use 2 smaller drivers instead.
Not sure what else should I post here :)
Which country are you in? That matters. I will try and pick a driver made in the EU.
I do need to know what sort of bass extension you are looking for. Those speakers are quite potent and according to spec, can achieve 113 db. That might be a challenge to match that at your budget, but if you don't play very loud then you won't need 113 db. The F3 of your speakers is 44 Hz, so despite size they have no deep bass to speak of. So crossover on the 60 to 80 Hz range will be appropriate.
I need as much information as possible so I don't waste my time.
You can start a new thread if you want, and that is probably a good idea. To make the thread useful you need to provide full information on your equipment, listening room, and how you intend to use the system.
bassbear
@TLS Guy greetings from Poland :)If it is not possible no need to go to 113db.
Let's continue here:
I will see what I can up with and try and pick a European driver.
I have done lot of research on this. I can not come up with a European driver. Pretty much all that I have designs for have been discontinued. The European manufacturers have reduced their catalogs.
In addition, particularly in Europe, there is a marked trend away from high Qts. drivers.
This is a trend that on the whole I agree with.
In the USA, as I have pointed out many times, there is this unhealthy preoccupation with the lowest F3. This war has come at the expense of bass quality. I can hear this when I listen to a lot of American subs. They may go deep, but the quality is often awful. This is not something that shows in standard measurements, but it sure does when you play it in your room, and especially in the smaller the rooms with the high Schroeder numbers. European rooms tend to be smaller than American rooms and so the deleterious effect of high Qts subs are all the more apparent.
Anyhow, I think you are best off using this Dayton driver per your specs.
As it so happens I have a design on file for this driver, and fully worked up, for a 12" sub that would be a very nice sounding sub. It is one I think you would be very pleased with, as you can see from the models. The size is also very practical. I actually worked this up as a design I plan to build for our family room.
I think that will be a very high value sub, that you would be very pleased with.
1Randy
The HO 18 ported with my box is a far better and more potent sub. It also takes a lot less power and does not need Eq. The T/S parameters of that driver are right in the sweet spot for a ported or TL sub.
Members who have built it have been very pleased with it.
How big (approx) of an Enclosure would be needed for the HO15" version ?
Thanks
I would bet that most European driver manufacturers have been sold.
SEAS for one have not been, there is Falcon acoustics in the UK, and they are making the KEF B i39 again as well as a range of drivers, and sales are hot. Volt are making some excellent drivers. I will look into it.
Italy has a bunch: - B&C Speakers, RCF, Lavoce, and FaitalPRO.
Peerless are still in business in Denmark along with Scanspeak.
Audax is still making drivers in France.
So, you don't have to buy inferior Asian products.
1Randy
I would have to model it.
Yes ,I understand.
We are fortunate to have you here with all your knowledge and experience designing "Quality subwoofers". Hopefully in the future I can build one with your insight and knowledge. !
1
1Randy
It is a big one!
Yes i agree, very big, i think something in the 6cu/ft (gross volume) approx 4cu/ft Net, is reasonable.. Especially if multiples in room.
Then you need a different driver. You will not get as low an F3. That driver has a very low FS and that is why the enclosure is large. You really don't need and F3 down to 20 Hz, 25 Hz or so is perfectly adequate.
You could do with a sealed enclosure, but then you will need a lot more power and significant Eq. Ported makes for a simpler project and I think they sound better. For what you are looking for, you need 12" drivers. That last 5 Hz or so really ups the ante.
1
1Randy
I noticed GSG Audio has 3 Driver choices for the Marty 15" Cube ( I think it's around 4cu/ft Net).
-15” high output driver (LaVoce WAF154.00)
Optional:
- Stereo Integrity SQL-15,
-Dayton RSS390HO
Optional:
-Dayton RSS390HO
Be careful with GSC their engineering is suspect and that is putting it mildly.
The vented F3 of the RSS390H0 is 33 Hz. So not an impressive sub driver for HT.
This will probably get you where you want.
If you want a clean F3, you will have a cabinet on the large size. This one is reasonable.
That makes it difficult, not a lot of good options in the EU. Where are you in the EU? 200 litres is 7 cu.ft. That is a gigantic sub. My first model will fit the bill of that driver is available in the EU.
