$90+shipping
I used this for one year in a an old ported box (used my NAD 2100 to drive it). The hard-foam was taken off to make room for the grill, but otherwise the sub is in great shape (and used very little).
DVC subwoofers are the most versatile drivers in the Dayton Loudspeaker line up. They were engineered to provide very good performance in sealed, vented, bandpass or even transmission line designs. The dual 8 ohm voice coils allow for use in a variety of applications and wiring configurations. Each driver features a heavy gauge stamped steel frame, super stiff Kevlar impregnated paper cone, thick foam surround, flat progressive spider, vented pole piece, dual high power Kapton voice coils, heavy duty braided tinsel leads, rubber magnet cover, and high-quality pushbutton terminals. Made in the U.S.A. 5 Year Limited Warranty. Specifications: (Note: All specifications are with voice coils connected in parallel) Power handling: 350 watts RMS/per coil, 600 watts total * Voice coil diameter: 2" * Le: 1.76 mH * Impedance: 8 ohm per coil / 4 ohm total * Re: 2.8 ohms * Frequency range: 20-450 Hz * Magnet weight: 112 oz. * Fs: 22 Hz * SPL: 87.4 dB 1W/1m * Vas: 4.25 cu. ft. * Qms: 8.69 * Qes: .40 * Qts: .38 * Xmax: 15.1mm * Dimensions: Overall Diameter: 12-1/4", Cutout Diameter: 11", Mounting Depth: 6-3/8", Magnet Diameter: 6-1/2".
