The DTS20, a.k.a. "Tower of Power", is simply the most powerful, lowest frequency reproducing subwoofer on the planet
Solid output down to 16 Hz, single digit distortion and incomparably low group delay put this amazing subwoofer in a class by itself.
The DTS20 is the perfect choice for ultra high-end home theatres, industrial/ military/research facilities, commercial cinemas, mastering facilities, electronic organ reproduction, and commercial surround sound recording/playback.
The DTS20 Tower of Power has removable covers that allow two different options for the location of the acoustical output which will be based on the installation orientation you choose. In either orientation It is truly an amazing sub-woofer and is absolutely bullet proof.
I purchased the DTS20 from Danley back in 2010 and used it for roughly 4 years.
Since then it has been stored in my previous home’s mechanical room, and most recently my current basement. Both of which were\are temperature and humidity controlled and smoke-free.
While in use it was never abused and only used with High-End home theater equipment, and as such it has never seen low nor high-power distortion. (FYI – It Is Serial Number 000100)
I was really hoping to be able to utilize it once again, hence the years of storage; unfortunately, the new home we moved\downsized into simply doesn’t have enough space for a home theater.
-SPECIFICATIONS FOR DTS 20-
Operating frequency range - 18 Hz- 100 Hz -3dB (16 Hz -10dB)
Continuous output - 122 dB SPL
Peak output - 128 dB SPL
Sensitivity - 95 dB SPL (2.83 Volts into rated Z, at 1 meter) measured in half space
Magnitude response - 18 Hz - 100 Hz
Driver complement - One 12" long excursion woofer
Dimensions - 87.5 x 18 x 20 inches
Weight - 220 lbs
Rated Impedance - 8 Ohms
Power Rating – 500 W Continuous (1000 W With Program)
Additional Specifications Can Be Found At –
www.danleysoundlabs.com
**NOTE**
The subwoofer and all internal parts are in perfect shape and fully functional, however It does have some scratches on the exterior of the box, although they are purely cosmetic and could easily be repainted if necessary. (See Attached Photos)
**SHIPPING NOTE**
Due to the size and weight of the Sub it must be picked up locally as it would be nearly impossible to ship economically.
Item location - Andover, MN 55304
