Bah. JL Audio. Overpriced and overrated.
You know they don't warranty their voice coils now? There is a reason for that.
Just some friendly advice.
You want output? Get a big ol' amp and buy a RE Audio XXX. They are the beafiest you can buy in reason. My buddy had a single 12" RE Audio XXX, ported at 28Hz, and he registered 148.7dBs. And it was only powered with a MB Quart Q-line 1000 watt amp (it's RMS is 1600). He simply used the standard ported box they have online and the truck was stock (no dynamat or anything).
www.reaudio.com (check out the XXX, even stronger is the MT, but I doubt you'll find an amp to handle that one to be honest, unless you have a lot of scratch).
RE Audio XXX:
RMS: 1600watts
Peak: 2500watts
I've seen them plugged into 110 outlets and they take it like nothing.
JL has NOTHIN on them.
Good luck with your project, PPLLLEEEASSSEEEEE keep me updated if you do it. I want to do a DIY home subwoofer (probably using an 18" XXX) at some point.
-Chad
