mazzini
<font color='#000000'>another question...
When I have the speaker switch set to 'Main+3rd' on the da5es, my center speaker does not work anymore... the four speakers and the sub will work in the main room as well as the 2 speakers in the 3rd room, but the center speaker is quiet. &nbsp;When I switch it back to 'Main Room' then all 5 speakers work.</font>
G
Guest
Guest
<font color='#000000'>What is your question exactly?
This is normal behavior. The 5ES has six amp channels. When you switch on the 3rd room, two of them are used to power the 3rd room speakers. Note that the 3rd room can play a different source than the main room, which is why these speakers need their own amp channels. That leaves only 4 channels for the main room, which is why the centre channel is turned off. Note that the centre channel signal is mixed into the left and right speakers instead.</font>
