mon2479
So I want to put a def. tech. 1000 center channel speaker above my VT30 on a little shelf. Here is my idea, I need all the input I can get
-use metal track rails, drill 2 holes in each rail, bolt them to the mounting holes with a washer
-they have to be even with the top of the tv
-clip on the shelf brackets on each rail
-place a light board across the 2 brackets and secure the board with 2 screws(1 on each side, at the tip of the bracket)
-lay down some light padding of some kind for the center channel (6lbs)
That's my general idea, I would paint everything black to make it look nice
