Cylinder VS. Box Sub?
jchag
I was looking at the SVSound wed and noticed the cylinder subs. I have been waiting for the SVS 13 inch subs to come out or the AV123 BMF1. How do the cylindr subs compare to the box subs? In my room I could probably use two cylinder subs instead of one box. Will that help? Would like to spend $2000 , but can go higher.
MDS
The SVS site has an extensive discussion of box vs cylinder in the FAQ section. The short answer is that they are equal in performance but the cylinders are lighter and cheaper to ship with the disadvantage being their large height.
jchag
Just read their entire FAQ section. Lot of information!!!
mkossler
mkossler
Not to mention that a search for box versus cylinder in this forum will return literally hours worth of discussion on the very subject. :)
Buckeye_Nut
I was looking at the SVSound wed and noticed the cylinder subs. How do the cylindr subs compare to the box subs? In my room I could probably use two cylinder subs instead of one box. Will that help? Would like to spend $2000 , but can go higher.
It's personal preference.....
Providing you are comparing between subs in the same class, both are capable of excellent performance. It's more about which physical design you prefer........... The decision between the two is mostly cosmetic.
Do you prefer a tube or a box?
Ryan8886
As everyone has said, performance-wise, they're pretty much equal. Which you go with depends a lot on personal taste. If desired, a box sub can be blended into the room as stand or end table, making it not as noticable. Translation= the wife is generally more tolerant of it. There is NO blending a cylinder sub! :D Translation= You're probably single or the wife is blind. :p It's definately a conversation piece for the uninitiated! I love mine!
jchag
After reading the FAQ at SVS I now have another question. It sounds as if the three different size subs have strenghs and weakness. If I use two subs would I be better off mixing the subs or use two of the same sub? the more I read, the more I need!! to read.
mazersteven
mazersteven
2 of the same subs. :D
Ryan8886
Call or email SVS with your room specs. They're a pretty small company and are known for being very helpful as far as which model or how many will suit your needs and wants.
