I'm seeking input on the following:
The SVS PB10-ISD, on sale for $379. Some Specs:
Proprietary, SVS-designed long-throw 10" woofer
300 watt BASH digital switching amp
Front-firing design with flush fit woofer and vent
+/- 3dB from 20-100hz anechoic, in room extension will be 2-5hz deeper
Size: 15" wide x 19" high x 21" deep
Weight: 60 pounds
The Mirage S12, on sale for $399. Some Specs.
Front-Firing Subwoofer / Bass Reflex With Two Downward-Firing Ports
1200 Watts Peak Power, 300 Watts Continuous
Woofer: 12" Polypropylene Titanium Deposit Hybrid With Ribbed Elliptical Surround™
Frequency Response: 19Hz-120Hz +/- 3dB
15.7" W x 19.4" D x 19.2" H
51 Pounds
AV123 Rocket UFW10 - B-Stock for $425. Some Specs.
500W amplifier with one-band parametric EQ,
Type: Acoustic suspension, single-driver system
Driver: 10" black-annodized alloy cone woofer
Frequency Response: 25 Hz +/- 2 dB
Size (W x D x H): 13 1/8" x 12 7/8" x 13 7/16"
Weight: 52 lbs.
The room is 12x18 with an 8 foot ceiling, so medium size. Use is 2/3 music; 1/3 HT. Musicality (is that a word?) is of primary importance, but some good thump for movies would be a plus.
System:
Pionneer 912K 6x110 watt receiver.
Fronts: Infinity RS3s
Center: A vintage AR 18
Surrounds: BIC Venturi DV52s
TV: Westy 37" LCD
DVD: Panasonic (Not sure of model # - it has progressive and record capabilitites)
No current Sub
I like the size of the Rocket, but the black color of the others.
