Robin DefTech
Hi,
I am Robin, a new member. Just joined. I would like to know what crossover settings should for the A/V Receiver. I know most says set the speakers to small.
This is my setup
Front (L & R) - Def Tech 8040ST
Center - Def Tech CS- 8040HD
Side Surround - Pro Cinema 600
Rear Surround - Def Tech - SR 8040BP
Sub - BIC PL200
Receiver - Onkyo TX Sr606.
My question is I don't see small crossover frequencies in the receiver. It just shows me
Full Band, 40Hz, 50Hz, 60Hz, 80Hz, 100Hz, 120Hz,
150Hz, or 200Hz.
And my another question is -- In Def Tech website, it shows to set the Speakers to Large; Full Bandwidth.
But I think that's because of built in subwoofer. So what exactly should I set? Full or small?
Any recommendation which new receiver to look for my speakers?
Thanks
Robin
BlwnAway
BlwnAway
In general my recommendation when not using an auto calibration room correction is to go a low as you can, to where they sound correct to you, I personally prefer a more full sounding speaker, but this is my personal choice, your settings will have to reflect your individual taste and the way your room effects the sound of your speakers. This is how I do it by ear. And it will take some time and tweaking, but it will also help you in learning what the effects of these types of changes can have on your setup and give you a better overall understanding of these things.
First make sure your Sub setting (LPF for LFE) is at 120hz. (this should be the default)
Then make sure your distance measurements are as close as you can get them.
Your Surrounds and Rears will take less time so I'll start with those.
Surrounds and rears:
Those all have 3.5" drivers, and most likely the settings will be the same for both positions, I would suggest starting at 120hz, (because of the driver sizes) then as you listen to some content, try dropping to the next lower setting, re-listen, simply repeat this process until you think the speakers sound as if they are straining or reverberating too much (lower tones will get muddy or sound as if there is a flutter in the speaker) then simply set the crossover to the next higher setting from there.
Center:
Speaker Wire only, same listening rules apply, but in most cases with the CS-8040 HD you'll want to start with 80hz, and most likely you'll find that 80hz or 60 hz is best.
Fronts:
These will be a little different, with speaker wire only to the speakers (no RCA cable to the Low input) first set them to Large and listen to them like that for a day or so. (Unless of course you hear something obviously wrong) and adjust the dual in the back to get the bass output that you like.
Then after a this, go back in, set them to Small, with an 80hz crossover, again adjust the dial in the speaker to taste, and repeat the steps you took with the other speakers. Once you find the small setting that works best for you in your room, then after a day or so, change it back to Large and compare, just choose what ultimately sounds best to you.
With all these settings, since you set them by ear, there is the chance that all of a sudden something just sounds off with specific content, then just simply go in and tweak the settings a little, manual setups can take small changes over time, but your not going to hurt anything in the process, just don't get in a hurry and take small steps.
If you want any other setup help, placement, toe in, feel free to ask.
If you would like to experiment with other types of connections to your Fronts, also ask, but do yourself a favor and live with them connected with speaker wire only for a while, so you have a good feel for them when experimenting further.
Good Luck
BlwnAway
BlwnAway
Oh, also, if you haven't done any setup yet and are open to suggestions on placement, I'd seriously consider using the SR8040's as surrounds and the 600's as Rears, rear positions usually work better with mono-poles.
I would try using the 8040ST as front, small and hold off on the BIC sub. It may sound best that way. How are you connecting the Def Tech speakers- you're using the sub input, right? If that's the case, you don't need to worry about the crossover setting and since you ARE using an AVR with correction, the Def Tech should be able to handle everything.
Hi,
This is my setup
Sub - BIC PL200
150Hz, or 200Hz.
Thanks
Robin
Small is the range of 40 Hz, 50 Hz etc settings
Full band is equivalent to saying "large". The silly thing is it should be bass management on or off, rather than this silly marketing language of small/large.
Do the "subs" in your floorstanders have separate input from the main speaker? I know some of the DT stuff has "powered subs" built in that can take an LFE/sub input. DT tends to overstate bass capabilities in everything they do, too. I think with your sub I'd try both full range or not and see what you like altho I generally recommend when using sufficient subwoofage to simply cross 'em at a point that makes you happy. I have speakers capable of a 60 cross easily enough, 40 would probably work as well but I cross them at 120 because I have sufficient subwoofage to take that load off the speakers. Not a lot of glory in that range for a lot of speakers anyways, better to offload to a good sub (preferably multiple).
Robin DefTech
Wow didn't realize I would get quick reply... thanks for the suggestions... When I'm back home I'll check the setting and keep you posted. Thanks a lot...
