Crossover settings for polk speakers
AJelco
I was just wondering what crossover settings I should set my speakers at as the crossovers that the audyssey set were way too low. My fronts are monitor 60 series twos, my center is a monitor 15c, my surrounds are r30s, and my surround rears are t15s. Is 80hz all around good enough or should I change some settings.
ryanosaur
ryanosaur
For your mains, I would experiment with 80-100Hz.
15c, r30 @100-110Hz
t15 @90Hz
I like an octave above... for me it sounds better rolling off to my subs. YMMV.
I've seen another gentleman that says he likes it more around 1/2 octave. Again, YMMV
-Jim-
-Jim-
Please describe too low? I'd start at 80 Hz for the fronts and probable 100 Hz for the surrounds and see how that sounds.
AJelco
15c, r30 @100-110Hz
t15 @90Hz
The receiver config my fronts at large. Should I leave it as is or put them small
Large/small simply means don't use bass management or not. With a sub(s) I prefer to use bass management and have my subs handle the lower bass. I'd also think 80 is a good starting point, and try 60, 70, 90 and 100 too....
